1. Review the Resolution and Response
Before following up, carefully review the response you received from Call of Duty Black Ops 6 Bot Lobbies Activision’s support team to ensure the issue was fully addressed. Sometimes a solution might involve multiple steps or require additional time for results to take effect. Make sure that:
The solution provided was clear and actionable.
The issue hasn’t occurred again after following the recommended steps.
You don’t need additional clarification or troubleshooting.
If you're still experiencing the same problem or if you need further help, proceed with the follow-up.
2. Contact Activision Support Again
If the issue persists, you can follow up directly with the support team. Here’s how to do it:
A. Reply to the Existing Ticket (If Open or Recently Closed)
Log into Activision Support: Go to Activision Support and sign in.
Find Your Ticket: Navigate to the "My Tickets" or "Support Requests" section.
Click on the Ticket: Open the existing ticket for which you want to follow up.
Add a Comment or Request Update: Most ticket systems allow you to add additional comments. In your message:
Explain that the issue is still unresolved or has reoccurred.
Provide any new information or context that may help the support team understand the problem better.
Politely request an update or reopening of the ticket.
B. Create a New Ticket (If the Ticket is Closed or No Response)
If the ticket is closed and the issue is still unresolved, you can open a new support request.
Use the same case number if it’s related to cheap Black Ops 6 Bot Lobbies the same issue for quicker reference.
In the description, mention that the previous ticket was closed but the issue persists. You might also want to mention any troubleshooting steps you’ve already taken based on their advice.
Revenir à « Vêtements XXL homme »
