In Path of Exile 2 (PoE 2), the Orb of Chance is an exciting and versatile currency that allows players to chance a random upgrade on a normal item, potentially transforming it into a rare item with powerful mods. Whether you're looking to craft the perfect item or get lucky with high-tier gear, the Orb of Chance plays a crucial role. This guide will cover everything you need to know about the Orb of Chance, including how to use it, where to farm it, and how to trade it effectively.
 What is the Orb of Chance in PoE 2?The Orb of Chance is a currency item that can be used to chance a normal (white) item into a rare (yellow) item with random affixes. While the odds of getting a powerful item are low, the Orb of Chance is a favorite among players for crafting unique gear and gaining rare items without spending Exalted Orbs or Chaos Orbs.Uses of the Orb of Chance in PoE 2
  1. Upgrading Normal Items: The Orb of Chance is primarily used to transform normal items into rare ones, potentially giving you access to powerful mods.
  2. Crafting Gear: Many players use Orb of Chance to craft specific items, such as weapon bases or armor.
  3. Chance for Rare Items: You might get high-value mods on certain bases, which can then be sold or kept for endgame crafting.
How to Use an Orb of ChanceUsing the Poe 2 Orb of Chance is straightforward, but understanding the best practices will help you maximize its value:1. Choosing the Right Base ItemWhen using an Orb of Chance, you must use a normal (white) item as the base. The rarity of the item is crucial, as the affixes on the item after using the orb are randomly generated. Here’s what to consider:
  • Item Base: Choose items with high potential, such as rare weapon or armor bases.
  • Low-Level or High-Level: Higher-level bases might result in more powerful affixes, but they require more careful consideration.
  • Item Type: Certain items, like weapons or helmets, have a higher chance of yielding good results with Orbs of Chance due to their mod pools.
2. Using the OrbSimply right-click on the normal item and select the Orb of Chance from your inventory. Once used, the item will transform into a rare (yellow) item, with random affixes assigned. You may get lucky with high-value mods, but keep in mind that the chances of a perfect roll are low.3. Repeated UsageYou can use multiple Orbs of Chance on different normal items to increase your chances of success. If you have a collection of low-tier items or bases, repeatedly using Orbs of Chance could result in high-tier gear.Best Items to Chance with Orb of ChanceWhile the Orb of Chance works on all normal items, certain bases are more lucrative or beneficial for using this orb. Here are some of the best items to chance:1. Weapon BasesWeapons, such as swords, bows, and axes, have the potential to generate powerful mods, which can result in high-value chanced items.2. Armor BasesCertain armor bases, like body armor and helmets, are also ideal for crafting, as they offer great mod pools for life and resistances.3. JewelryChancing rings and amulets with the Orb of Chance can yield some of the best modifiers for stats, resistances, and attributes.
How to Farm Orb of Chance in PoE 2There are several ways to earn Orb of Chance in PoE 2. While it’s not as commonly dropped as other currencies like Chaos Orbs, it can still be farmed efficiently through various methods.1. Farming Regular LootOrbs of Chance can drop randomly from loot chests, monster kills, and other in-game events. These drops are relatively rare, but running high-level maps, bosses, and Delve runs increases your chances of earning them.2. Divination CardsSome Divination Cards offer Orbs of Chance as rewards. Keep an eye out for cards that offer multiple Orbs of Chance when completed.3. TradingTrading is another efficient way to acquire Orbs of Chance. You can trade items or other currency with other players for Orbs of Chance, which can be a great way to increase your stock quickly.4. Vendor RecipesCertain vendor recipes allow you to exchange other items for Orbs of Chance. While not common, this method can be a convenient way to obtain them.
How to Trade Orbs of Chance for ProfitIf you're looking to make a profit off your Orbs of Chance, there are several strategies you can use:1. Crafting and SellingUse Orbs of Chance on valuable items and craft high-demand gear to sell for other valuable currency or items. Items that have high rolls can be traded for Exalted Orbs or Chaos Orbs.2. Flipping Orbs of ChanceInstead of using them on items, you can flip Orbs of Chance by buying low and selling high. Monitor the market and look for deals where Orbs of Chance are undervalued or items chanced with Orbs of Chance are priced lower than their potential worth.3. Buy and Sell CurrencyIf you're looking for quick profit, you can trade Orbs of Chance for other currencies (such as Chaos Orbs) or items in demand, making sure to leverage the market.
Tips for Using the Orb of Chance WiselyAlthough Orbs of Chance can lead to high rewards, they should be used carefully. Here are some tips for maximizing the value of your Orbs of Chance:1. Don’t Waste Them on Low-Tier BasesAvoid using Orbs of Chance on low-value bases. Instead, focus on items that have high potential for valuable mods.2. Use Orbs on Endgame ItemsUsing Orbs of Chance on endgame gear such as high-level weapons, armor, and jewelry will give you a better chance of crafting valuable items.3. Be PatientThe Orb of Chance relies heavily on luck, so don’t expect perfect results on every item. Be patient and keep using it on different bases to increase your chances of success over time.
Where to Buy Orbs of Chance SafelyIf you want to buy Orbs of Chance without the hassle of farming them, make sure to buy from trusted sources like SSEGold. SSEGold is known for:
  • Safe transactions with secure payments
  • Competitive prices
  • Fast delivery of Orbs of Chance
  • 24/7 customer support
Buying from reliable sites ensures that you get legitimate Orbs of Chance and avoid the risks of fraud or scams.
ConclusionThe Orb of Chance is a fantastic tool for any PoE 2 player looking to craft powerful items and enhance their gameplay. Whether you're farming, crafting, or trading, the Orb of Chance provides an exciting way to earn rare gear and valuable mods. By using the right strategies and purchasing from trusted sources like SSEGold, you can maximize your chances of success and make your PoE 2 experience more rewarding.
Revenir à « Vêtements XXL homme »
